losing prime question
Old Oct 26, 2009 | 10:12 AM
turfguy's Avatar
hey folks, been perusing the archived thread for a month or so now, & had a question. my 95 has lost prime because it sat for a month or so, & when I manually pump the LP it doesn't feel like theres any pressure when the fuel filter gets full (On my 94 it still does like normal). I replaced the fuel filter & while it was off, I pumped the manual button on the LP & fuel came squirting out each time. Would it possibly be a bad O-ring thats making squirt, but not enough to feel 'normal' when the filter is on? trying to not have to take it to a mechanic tomorrow-thanks
Old Oct 26, 2009 | 11:11 AM
rich's Avatar
shouldnt feel like a lot of pressure do to return lines. their is a rubber hose behind the injector pump some times it gets rotten and allows the it to lose prime but it wont leak. took me about a week of searching till i found it
Old Oct 26, 2009 | 11:38 AM
diezel freak's Avatar
when it loses prime did u losen the bleeder screw in top of the fuel filter base? if so were u geting bubbles or steady fuel?
Old Oct 26, 2009 | 05:32 PM
Steve Roseman's Avatar
Could be the spring on your bypass valve is weak.
Old Oct 26, 2009 | 07:38 PM
othomas3's Avatar
I Vote for Replacing the Bypass Spring
I had a similar problem and it was the bypass spring in the overflow return valve. You can stretch your original and see if that fixes the problem or not. If it does you can drive on the stretched original while waiting for the new one to arrive.
Olin
Old Oct 26, 2009 | 08:50 PM
b.lee's Avatar
When this happened to me I had leaky fuel lines running from the tank up to the pump.
Make sure those aren't leaking
Old Oct 27, 2009 | 06:41 AM
I had to eventually change the fuel lines on mine too. Checking the spring is a much easier fix if that's the problem. Start simple.
Old Oct 27, 2009 | 08:15 AM
John Faughn's Avatar
Testing is always the best way to find & fix .
Fuel pressure test .
It could be about 6 different things , it would cost too much to just replace everything .
If the pressure is low , pinching the return hose [ with gauge hooked up ] , if the pressure comes up , then it likely the OVF overflow valve .
If not then it could be the LP lift pump .
I have done both , now have the same issue again , and figure this time it may be the pickup in the tank , because it starts normal above a 3rd of a tank .
Old Oct 27, 2009 | 10:58 AM
CarlJensen's Avatar
Look at Joe G's write up. A lot of good info.
http://www.cumminsforum.com/forum/94...m-writeup.html
Old Oct 28, 2009 | 02:20 PM
turfguy's Avatar
I opened the bleeder, & it trickled some bubbles sporadically, but still feel no 'pressure' when pumping the LP bulb manually. Its like there's an air leak keeping it from building pressure.... I can't use a fuel ppsi gauge yet, cuz I can't get it started..........
Old Oct 28, 2009 | 02:21 PM
turfguy's Avatar
checking the overflow byp. spring next....
Old Oct 28, 2009 | 02:38 PM
turfguy's Avatar
well the spring was broken & about 1/8" shorter than normal-gettin a new spring now..... can't believe they make ths stuff so cramped you can BARELY get hands in, let alone get the nuts & bolts squeezed in & out
Old Oct 28, 2009 | 07:28 PM
turfguy's Avatar
anyone know the part# of the tapered spring? my local cummins dealer doesn't have stuff for the 5.9- durrrr..............................I may have to go to napa
Old Oct 28, 2009 | 10:05 PM
patdaly's Avatar
Don't believe you can buy just teh spring for the overflow, get a new overflow valve, Fleabay usually has them for 30 bucks or so.
Old Oct 29, 2009 | 10:50 AM
infidel's Avatar
Some people use a spring from a Bic pen but I think it's a lame idea.
Search on ebay for Cummins overflow valve where you can buy an OEM valve for $30.
His shipping is very fast.
Crimedog
16
Oct 28, 2006 01:23 PM
smokeyram
Apr 5, 2006 07:17 PM
cmckinney
43
Mar 16, 2006 04:13 PM
GearHd6
Nov 4, 2005 06:51 PM
cummins2
13
Jan 21, 2005 04:56 PM
