looking for P-7100 Timing tools
Old Nov 7, 2011 | 04:58 PM
diesel yukon's Avatar
I'am looking for a place to buy the tools to time my pump, at a good price where should I look? I have a Baring tool, But was wondering where to find the rest of what I need.
Old Nov 7, 2011 | 05:42 PM
patdaly's Avatar
Back when I was a newbie, I got this advice, works well for us financially challenged folks...
"1. Well, You can get a delivery valve socket from piers diesel for $30.
2. For the dial indicator, Harbor Freight sells them for $10, and it works just as good as an expensive one. It has been used ot the forum more than once. The only prob. with it is it is in inches. That isnt a big deal, because if you search on DTR people have converted the mm to in. measuremens.
3. For a dial indicator holder, you can use a drain plug from our cummins. I went to autozone and they had one for $5.00. You just drill out the center so the dial indicator slides in there. Then you need to drill and tap a small hole for a set screw in the side of the drain plug, so the indicator doesnt move.
4. For the gear puller, any cheap steering wheel puller will work. You can get them from auto parts stores, for under $20.
I did mine this way and it worked out great. I looked on ebay and came across a metric dial indicator for cheap, after I did it with the inch dial indicator.
There you go, under $70.
Also, I dont recommend it, but I have read on here people use a set of chanel-locks and a rag to get the delivery valve holder off. The only prob. with that, is re-torquing the holder, to much and you will tear the o-ring and you can only get it at a bosch dealer, I guess its some weird size."
Skip H
May 21, 2010 06:30 PM
John Faughn
Jun 23, 2009 07:51 AM
Dr. Evil
Oct 2, 2008 01:17 PM
GR40RCapri
Jun 25, 2006 12:53 AM
