limited slip question
Old Jun 24, 2008 | 01:59 PM
Brendan's Avatar
Question limited slip question
I replaced all my fluids with royal purple not long ago, and I was told I didn't need to add anything for the limited slip because it is a synthetic lubricant. Now when I am in parking lots and other similar situations I get lots of inside tire chirp and clunking. Is this fairly normal for an unloaded truck?
Old Jun 24, 2008 | 02:34 PM
Lil Dog's Avatar
Fairly normal for no slip additive in the oil. If you want to reduce that problem, just add a little of the Mopar LSD additive. The synthetic lube is better, but doesn't entirely remove the need for the additive.
Old Jun 29, 2008 | 09:05 AM
Ronco95's Avatar
Go to the dealer and by the additive. Slowly add an ounce at a time until the condition goes away. I used the whole bottle at once, and I have times when the diff will not lock and I need it the most. I am going to have to drain mine and slowly add additive.
scout98
Sep 6, 2007 08:22 PM
shawn085
Nov 21, 2005 12:46 PM
dkinzer
May 23, 2005 08:57 PM
Shaders 24v
Dec 8, 2003 12:29 AM
