Limited slip question
Did all trucks ship with some type / brand of limited slip differential?
The reason I am asking is I only have 1 wheel that spins when I lose traction. Is this just a sign that someone did not get the friction modifier correct at fluid change?
Not all are/were built with the LS rear end. The modifier could be missing/diluted or the friction pads may be worn out. A build sheet is available from any Dodge dealer with your vin # or look on the diff cover for a tag. It should also be listed in your glove box on the sticker in there
Shaders 24v
Dec 8, 2003 12:29 AM
