lift pump help..
lift pump help..
ok i need to clean out the lift pump screen... my hanes manual has nothing on lift pump...i saw a thread on this but for some reason i cant do a search pc wount let me.?
thread had i pic by pic of removal also deleted heater element and reinstall...can any one help with this...looks fairly simple.
On my '98 it is a small cone shaped screen slipped into the fitting on the inlet side of the pump. Pretty simple except hand clearance. Undo line, remove fitting from pump and the screen is there. Took a little ***** punch to pop it out.
Here you go> http://dodgeram.org/tech/dsl/filter/pre-filt_clean.htm
Ditch that Haynes manual before it gets you into trouble and buy a real manual here> http://www.genosgarage.com/products.asp?dept=241
cool thanks Bill i will get that manual ...
umm my local dealer says dodge did away with lift pump and cant buy parts for it.. none of my auto stores now anything.. were do i find a cummins dealer tried a search but nothing....
also that post helped alot..thanks
While you are ordering that FSM, you can get a kit, 7.95..... Be aware, it is REAL easy to spend money at Genos.......
http://www.genosgarage.com/prodinfo.asp?number=3845400S
rtmick
Jan 19, 2007 07:02 AM
Haulin_in_Dixie
47
Nov 17, 2002 09:30 PM
