leaking tranny lines, quick fix?
Old May 4, 2010 | 11:52 PM
94ram's Avatar
two of my lines rubbed together and eventually made a hole in each line. its the steel lines going to and from the cooler.
could i be able to cut the section where the holes are and just reconnect with some rubber hose and clamps?
Old May 5, 2010 | 05:28 AM
blackimpala's Avatar
Yes you can do that. I replaced mine from the trans. to the cooler with hose, need to change the fitting on the transmission. Make sure the hose is rated for use with transmissions. If you are only cutting out the bad part I suggest you use two clamps on each end of the hose.
Floyd
Old May 5, 2010 | 07:05 AM
94ram's Avatar
yeah the idea was to just cut out the bad section and use one clamp on each side. could hydraulic hose work, something that is rated for 8-10,000 psi?
Old May 5, 2010 | 09:50 AM
infidel's Avatar
Hydraulic hose is too hard to clamp down, any hose that is resistant to hot oil will work.
Pressure in the lines never exceeds 10 psi, pressure isn't a worry.
Many people cut the line in just one place right where the leak is and slip the hose on rather than cutting out a section.
Old May 5, 2010 | 04:14 PM
94ram's Avatar
ok thanks ill get that fixed today.
D384D
14
Oct 26, 2010 10:23 AM
stange
May 8, 2010 01:34 AM
MrKen
Feb 25, 2005 04:22 AM
hellotbone
Sep 1, 2003 08:46 PM
