leaking rear seal
Old Mar 4, 2008 | 02:57 PM
jhagga007's Avatar
Question leaking rear seal
Has anybody replaced the rear seals?i need to replace the one axle seal ,one side is leaking and while i m at it,also check on rear wheel bearings,do ineed any special tools for this, or a shop press?, i also need to pull the axle out in order to do this right??,thanks for your help.its a 97 2500., 220,000 miles on the clock.
Old Mar 4, 2008 | 03:50 PM
dozer12216's Avatar
Believe can rent special socket(big) to take hub adjuster nut off. Rest is fairly easy, abeit heavy. Don't leave nut tight.
RTillery
Feb 7, 2009 08:46 AM
pwrtripls1
Jan 7, 2008 08:55 PM
gotmuddy
Oct 16, 2004 02:54 AM
dieseljerk
Jul 8, 2004 07:23 AM
