leaking coolant
Old Aug 16, 2006 | 06:40 PM
wana12v's Avatar
leaking coolant
i ran the truck hard today and when i shut it off it started puking coolant. I discovered it only does it after I shut the truck off I can run it hard an let it idle and none leaks then I shut it off and it starts puking? it look like it's comming from the bottom passenger side?
Old Aug 16, 2006 | 06:43 PM
singleturnout's Avatar
mine did the same thing found out there was a 4 inch crack in the block but mine was a 24v with the 53 block,woundnt leak while running but as soon as i shut it off then it would start dripping
Old Aug 16, 2006 | 07:48 PM
bump
Old Aug 17, 2006 | 06:38 AM
wana12v's Avatar
it's leaking from the radiator, i just dont get why it dosent start until the truck is turned off.
cutthroatxxx
17
May 22, 2015 07:09 AM
fiveninefo
Sep 21, 2011 12:02 AM
Mark Hodowanec
Aug 17, 2009 11:56 AM
popeyesides
Dec 6, 2004 03:43 PM
DTE
Oct 8, 2004 07:02 AM
