KDP kit install
For what its worth, my case cracked about 4-5 inches long from where the case cracked on the outside up toward the pump. Was fairly ugly. This was even at idle when I heard the pin fall at startup. Just imagine running down the road with it falling out. Ive seen the cases on ebay for 50$, but you wont find that good of a deal when you need it though. And for fan removal just put a smaller pipe wrench on the nut and get it a smack with the belt still installed.
Thanks, I think I'm going to check mine to see if its been done
Instructions at the bottom here> http://www.cumminsforum.com/forum/94...tructions.html
That's the only way to go.
I just got finish with repairing my truck correctly, at first I did a temporary repair with JB weld and seemed to bond well when I first did it But when my new case came in and I removed the old case the peice that was JB welded in poped out without much effort.
I pulled the gear off the camshaft and then heated it back up to slip it back on, Not too bad to do
Thank you to those that contributed
sootnsmoke
Jan 5, 2012 08:55 PM
