Kdp Jig?
Originally Posted by TIMMY22
Is there really a jig for drilling a hole in the front cover to block the pin from falling out? has anyone had success with this method?
I feel the jig fix is totally adequate for the dowel pin, I've personally used it on well over 50 engines. Takes about 45 minutes, the only new part needed is one bolt.
If you can change your own oil you can use the jig.
In fact the only reason I wouldn't use the jig is if you have a leak from the front seal, cover or case that requires taking things apart anyway. Remember you are only preventing a problem that won't happen for the vast majority of engines, why make it complicated? Bolts could come loose all over the engine, should I take the whole thing apart to tighten them?
A jig kit is available from Harold at rvhvnfn@juno.com or 208 850-8749.
$30 gets you the basic kit, postage paid.
Originally Posted by wana12v
i had mine done the with the jig fix and he pressurized the motorso that it blew all the shavings out instead of letting them fall in. it was a neat trick
What am I missing here?
The kit I use (Harold's Jig) comes in at an angle and hits the end of the set screw. With a good flashlight you can see the pin to verify that it's in place, and you can tap on it with a punch to reseat it if it has slid out some.
Wow, Bill! Over 50? I have some catching up to do!
Originally Posted by russ300h
Maybe my situation was a 1-1000 shot. In my case, the pin was almost all the way out. A drill would have pushed it the rest of the way. Then I would have put a bolt in covering a hole with no pin. With my luck on startup the gears would have picked it up and caused the problem I was trying to prevent. It would have worked fine on my friend's '96 His was fully in the hole.
I've only used the John Strenkowski (CPFF) jig. It is the original and he freely distributed many sets around the country to TDR member volunteers that would track them.
One of the guys learned a trick to minimize shavings dropping in the hole. Use the pilot drill to mark the aluminum cover, but not drill completely through. The countersink operation produces most of the shavings, but without a through hole they drop harmlessly away. Complete the pilot drill and tap.
Originally Posted by NHDiesel
Old machinists trick: put a good amount of grease in the flutes of the drill bit and tap before use to caqtch the shavings. Remove, clean, and regrease a few times.
Jim
Jim
Tapping especially in aluminum requires a good lubricant to prevent gauling.
I always pressurized the engine to about 10 psi with compressed air while using a jig but it can also be done with a vacuum cleaner on blow.
In the one instance I ran into a pin that was too far out and blocked the drill I continued with the tapping and countersinking. Took the cover off to pound the pin in and there was only one little flake of shaving that had fallen in.
