KDP fix in Virginia Beach
Old Jun 9, 2004 | 07:27 AM
360ramcharger's Avatar
Hi All.
I just bought a 97 2500 4x4 Auto Quad cab it has 134k miles
I really need some help to get the KDP fixed, I saved for years to pay for this truck and dont want this to end it for me. if there is anyone in my area who can help with loaning the jig kit or doing the fix please let me know. if not could you direct me to the person who makes the kit. I've been reading these fourms for a while trying to learn about these trucks and I aint even close.
thanks Yall
Mike
Old Jun 9, 2004 | 04:06 PM
Harold Bowers made the jig I use, his email is rvhvnfn@juno.com I believe. Make sure you get his fan wrenches, they are a must and a great deal, too. Or if you have any business that brings you near the Philly area I'll fix it for you.
Old Jun 9, 2004 | 05:27 PM
DZLPWR's Avatar
Timinva is around Va Beach, he may know of someone who can help you out.
Old Jun 9, 2004 | 09:49 PM
jaconst's Avatar
what are the fan wrebches for??
personally I'm having my diesel shop DIS do the KDP fix but they are actually going to remove the timing cover and check everthing over and fix any leaks then put a #10 plate on 4000 GSK and 60lb valve springs a pyro gauge boost 60lb gauge all installed parts and labor $1260. parts are $800 alone and they will do a professional job and all required adjustments
Old Jun 10, 2004 | 07:31 AM
thanks for the help! I was close to PA this past weekend wish I new about your handy work. Ill try timinva to see if he can help
This KDP is like sitting on a time bomb with no clock!
Old Jun 10, 2004 | 08:06 PM
For getting the fan off. The fan is threaded directly onto the fan hub, and it's reverse thread so the engine rotation tightens it. The fan nut is pretty big, but not very wide, and there's not really any good way to hold the fan hub. Harold's fan wrenches are cut out of steel plate so they fit in the narrow space. One fits the fan nut, and the other one is cut in sort of a flower shape to fit around the bolts that hold the fan pulley on. Works great for getting the fan off, much neater than the ol' hammer and punch trick.
Pungo Farm
Mar 17, 2013 01:36 PM
sootnsmoke
Jan 5, 2012 08:55 PM
Smokin96_12v
Oct 12, 2009 07:39 AM
dodge2001
VADTR #7
Nov 6, 2008 04:55 PM
$oC@l CTD
Oct 17, 2007 06:16 AM
