KDP done here Too
Old Nov 26, 2005 | 10:37 PM
nerka992003's Avatar
Thumbs up KDP done here Too
Just finished killing my KDP last night ,was a pretty easy job ,although the tips and advice I got on here sure helped me lots .I'm by no means a mechanic. My pin was sticking out about 3/16",Was great knowing when I turned my engine over this morning that pin would not be causing me any grief.
97' CTD 4x4 K&N KDP killed
Old Nov 26, 2005 | 10:46 PM
Geico266's Avatar
Nothing like a job well done. Congrats!
Old Nov 27, 2005 | 06:34 AM
firesine's Avatar
which method did you use? i need to get it done myself, soon. found a mech who will do it for about 200. but....
john
Old Nov 27, 2005 | 11:03 AM
TxDiesel007's Avatar
Firesline
I bought and used the KDP Repiar Kit from TST... piece of cake, and u get to better know the front of your engine.. Just FYI here is an honest writeup that I wrote in regards to this....
https://www.dieseltruckresource.com/...Repair+TST+kit
I would encourage you to do it yourself, its not hard at all, just basic wrenching....
Tx
Old Nov 27, 2005 | 11:45 AM
Smile
I used the kit from TST also, was nice to have everything in one kit.
I'm glad I took the time to research and ask some question on this site ,it is a very easy job nothing to complicated. I took the fan shroud out along with the fan .I did find out there is a wire that needs to be cut from a tie-stap thats attached to the bottom of the shroud. My biggest problem was the coolant and washer fluid tanks,theres little ***** on the back of the tanks you can't see so if you stick something in there to pry a little while you lift they pop right out.
97' CTD K&N KDP killed
6.7L MegaCab
30
Nov 10, 2011 10:36 PM
pwrtripls1
Jun 6, 2010 10:26 AM
Smokin96_12v
Oct 12, 2009 07:39 AM
mainer
Oct 23, 2007 02:42 PM
Ramdriver15
Jan 24, 2007 09:33 AM
