Just got my new injectors!!
Old Jan 14, 2008 | 11:42 AM
Ru rammin 2?'s Avatar
Talking Just got my new injectors!!
I just got my stage twos from pensacola and they are four holers and they are bosch and they came with new horse shoes, new copper washers, and new sealing rubbers. $218 shipped to my doorstep.
Old Jan 14, 2008 | 11:46 AM
Box5's Avatar
Let us know how they perform, I might be interested in a set. Also, could u compare mpg before and after?
Old Jan 14, 2008 | 11:54 AM
I could somewhat but I don't have a accurate number now being as I run red dye most of the time and the truck is getting timed, a new overflow valve, and a 3k gsk along with the injectors.
Old Jan 14, 2008 | 01:19 PM
motochamp250's Avatar
sounds pretty sweet! let us know how they do im considering some....
Old Jan 15, 2008 | 10:09 PM
Ocmechanx's Avatar
Bump
Kinda wonderin about them myself
Old Jan 15, 2008 | 10:44 PM
thewished's Avatar
Ditto, there are a few people running them and all I've heard is that the stage 2's are a little smoky but I'm sure WAY better than 370's
Old Jan 16, 2008 | 11:37 PM
Ocmechanx's Avatar
Bump......................
Old Jan 18, 2008 | 08:41 AM
WVAussie's Avatar
Do you have em in yet?
Old Jan 18, 2008 | 10:15 AM
thewished's Avatar
bump
Still wondering, but my diesel shop said stock bosch injectors are 6 hole and "good" injectors are 7 or 8 hole? So how could 4 hole be a bosch?
Sorry I'm such a newbie with injector stuff
Old Jan 18, 2008 | 01:29 PM
GAmes's Avatar
Originally Posted by thewished
bump
My stock 215s have 4 holes.
Old Jan 18, 2008 | 02:41 PM
gomerpile's Avatar
stock first gen injectors on the non I/C were 4 hole, as are the 40 horse bosch injectors im running in mine
Old Jan 18, 2008 | 07:19 PM
97 D-Tec's Avatar
i bought a set n i love mine i just need to get a better turbo and a trans to take full advantage of them
Old Jan 18, 2008 | 08:53 PM
I love the power. I just finished driving it and it runs like never before. The smoke was no worse and probably less smoke than before with stock injectors. I also advanced the timing and that helps I think. I would recommend them at this point. The pyro gets hot fast but I'm up at 6000 ft and have stock straitpiped exhaust. If you run better exhaust that probably helps. They are bosch and they are 4 hole.
Old Jan 18, 2008 | 11:02 PM
thewished's Avatar
Well it sounds like they are worth it, but with the wrong plate they will be to much for a stock turbo. I am thinking about the stage 1's just because I only want to be 350hp or so till I can afford a turbo then I can go big on injectors. You said it gets hot? How hot are we talking?
And are you running stock 131 dv's or upgraded dv's??
Old Jan 21, 2008 | 02:26 PM
stock dv's and a groung 0 plate. I think the timing was slipping because once the timing jumped and I limped it home and set the timing and torqued it right then the egt's are no hotter than before. I haven't pulled anything yet with it but I bet it would do fine. It made 45 psi boost though and that's too much. I'm gonna have to wastegate it around 35-38 but and it should be fine. I recommend the mods. Not much can outrun me now!!!
