Just got a 97 12v...got alot of ?'s
Here is TSTproducts I like there install alot. Also you get a plate and a KDP kit in one saveing money!
http://www.tstproducts.com/index.asp...ROD&ProdID=192
[click]
Commence countdown for driveline failure from excessive bombing...
I'm just ribbing you of course. I have a truck the same year and watch yourself, just a little more power, just a little more, a little more...
Hook it up to a sled! I dare you! ...chicken, bawk bawk bawk. It's not like you're going to do it all the time right? Just once... [snicker]
update
Hi all,
I got the Gauges: pyro and boost, installed and every thing works, but I need to drive it some more and see how she goes. The TST #6 plate works great not to much power yet approx 250HP an 635TQ. Great instructions and every thing worked out smooth as far as I can tell. I need to dial her in; I have black smoke between 3 & 4 gear merging on the highway. Other wise great! Defenitly needed to change the fuel filter and pre-filter on the Lift pump, they where dirrrty! Also could I be making more than approx 250HP and 635TQ with the mods that I have?
Next fuel lines and 3000GSK...any thing else I need to do?
Thanks
-Jesse
Thanks
-Jesse
Hi all,
Thanks
-Jesse
Thanks
-Jesse
. However, eventually you'll probably want bigger injectors or maybe a water/meth injection. You'd only NEED the water/meth injection to cool down the EGTs of course
. Just because you can also get an extra 50hp or so from the water/meth setup is secondary to the cooling effect of a pure water injection
pwrtripls1
Jun 6, 2010 10:26 AM
BigBully
Sep 29, 2005 12:27 AM
