Installed Transgo--No overdrive
Old Mar 9, 2010 | 02:28 PM
blackimpala's Avatar
OK I guess I belong to the school of, If its not broke fix it until it is. I just installed a transgo TFOD kit in my 47re it shifts great but no overdrive. At about 45MPH I can feel it go into, what I think is, lock up but the RPMs stay pretty high around 2300 to 2500 @ 60MPH I just checked the fluid level and the electrical connector on the transmission. Both were good. What else could I have screwed up? Maybe the TV cable? I think it was one that I had to disconnect to take the valve body out. Everything was fine before I started this. Any additional thoughts? If some one has a link to a TV cable adjustment that would be very helpfull
Floyd
Old Mar 9, 2010 | 10:28 PM
Fueling around's Avatar
Start here
http://www.dodgeram.org/tech/transmi..._lever_adj.htm
Items in the transmission that control O/D engagement: VSS (2WD), governor pressure sensor, & tranny temp. All are electrical connections.
BigDogJeepin
Apr 13, 2016 01:01 AM
klx650a2
Sep 5, 2008 12:40 PM
Need95-00CTD
Jun 26, 2007 07:48 PM
wcbcruzer
Apr 8, 2007 02:06 AM
Juiced06
Mar 15, 2007 01:23 AM
