Injector removal / replace
I'm going to pull my injectors this weekend and have them pop tested - I'm having trouble w/ blue/gray smoke at idle - even when fully at temp.
I'm going to use the short piece of pipe w/ a 14x1.5mm bolt to pull them.
My questions are regarding reinstalling.
1. Do I just reinstall all the lines and crank until she fires or do I need to leave the lines 'cracked' until I bleed the lines of air?
2. What size is the hold nut nut for the injectors? ie: what size socket do I need?
Any other suggestions are appreciated.
BTW
The nice part is the shop that is recommended for testing is in the same block as my office - litterally around the corner.
They charge $9.54 per injector to test and $23.10 per injector to re-build - sounds reasonable to me. Is this the norm?
BTW
Make sure to undo the lines, both supply and return completely from the pump and injectors and remove them totally. Bending them out of the way can make reconnection very difficult and can damage the lines.
Be sure to clean up the return line where the bango bolts sit with some emory paper and use new washers. Keep everything spotless. Any tiny bit of crud will end up in the nozzles. Blow out the lines before you put them back on. That price seems good for rebuilding.
HUNTINNUT
Jul 27, 2013 11:40 AM
trik396
Jun 1, 2008 07:04 PM
kawi600
Jan 26, 2006 10:19 AM
