Injector line leaking
Old Sep 14, 2007 | 04:56 AM
DZLNUT's Avatar
Raised the hood day before yesterday just checking oil and seen fuel around #1 injector. So i took a towel and dried the fuel off and started the engine it didnt leak real bad at first but after it set for about 10 min. it was all wet again. You can see where it has run down the side of the engine. The question i have is will it be the injector leaking or the line it self? Also are there seals under the nut on the injector line? Any response will help. Probably gonna just order an new line for this cylinder.
thanks Brent
Old Sep 14, 2007 | 06:23 AM
atthepark's Avatar
I had the same thing on my 1996, and i replaced the injector line on cyl. #1 and it has been fine ever since. Just make sure that the line runs exactly like the original and nothing else puts any pressure on it.
Good luck.
Old Sep 14, 2007 | 12:28 PM
dieseldemon's Avatar
No seals just a flared end.
Old Sep 18, 2007 | 03:24 AM
MikeR's Avatar
Take your 19mm (or 3/4) and slightly loosen the line, then retorque it, clean the area and start it and check for leaks.
It'll probably reseal, best to try that before throwing money at a new line.
AAmeeting
Nov 3, 2009 11:32 PM
dodge_diesel
Sep 5, 2008 10:26 PM
adidasman23
14
Nov 13, 2006 01:14 PM
berner
Mar 7, 2004 09:02 AM
bwat4
Feb 6, 2004 09:32 AM
