injection pump differences?
Old Jan 16, 2007 | 10:44 PM
Brendan's Avatar
What is different between the differnt hp rated p7100s, and can earlier units be modified to similar levels (of potential) as the later units?
Old Jan 17, 2007 | 07:03 AM
Jetpilot's Avatar
There are many differences between the different pumps, P&B's, cams, etc. The cost to modify a lower HP pump into a 215HP pump would be very expensive. It could be done but it would be much cheaper to just purchase a 215 pump rather than try and mdofy an existing pump.
If HP is what you want a 180 pump can be turned up way past a stock 215 pump by going with 13mm P&B's. The 215 and 180 share the same cam design so basically it would make the same HP as a 13mm 215 pump (stock for both pumps is 12mm).
Doug
Old Jan 17, 2007 | 09:02 PM
Brendan's Avatar
With that answered, how far will my 94' pump take me hp and tq wise?
Old Jan 17, 2007 | 09:40 PM
wtmtnterror's Avatar
Doug
So this may be a dumb question....what are P&B's??
Old Jan 17, 2007 | 11:17 PM
Fueling around's Avatar
Plunger & Barrel. Basically a little piston fuel pump for each injector
tommurray
Feb 23, 2014 10:38 AM
Hodge
Oct 26, 2012 12:41 PM
ups132
Oct 11, 2009 04:27 PM
clarkoh
27
Sep 3, 2006 09:01 PM
Yukon Dodge
18
Jul 1, 2004 10:08 AM
