increasing rpm by itself
I adjusted the idle speed tonight to get it back to where it should be. I only raised it roughly 50 rpm (sped is 780 rpm).
When I went to drive it, when you pushed the clutch in to shift gears, the engine would climb by itself. not real fast, but I turned the engine off @ 3000 rpm.
It did this 3 or 4 times before I could get back to the house.
I couldn't see anything that would be affecting the throttle linkage in any way. So I adjusted the rpm back down to 730 or so, and now it doesn't seem to be doing it again.
Any ideas as to what happened ?
GSK has been installed for well over a year.
I adjusted the low speed idle screw about 1/2 turn.
Idle after I adjusted it was roughly 780-800 in neutral with a/c on. Spec is 780.
royta
14
03-09-2005 05:19 PM
PapaPerk
12-05-2004 10:14 PM
fishin fever
02-22-2004 08:32 PM
