I'll try it one more time
Hello, I didn't get a response the last time I posted, so I'll try again.. When I start in drive, the trans. chatters. Once it shifts into 2nd & 3rd it works fine. it will do it empty, but more noticeable when I got my 5th wheel RV trailer hooked on..
hi
how would this be a t q prob when the convertor clutch is not engaged ?
maby just a trany mount / motor mount ?
or a bad sensor / speed / govenor ?
low line psi ?
if the vertor were bad it would not stop chattering?
help me understand ?
low line psi ?
Will do some checking today.. I'm in south Texas right now, & problem here is there's a transmission shop every mile, & I'll have to try & find one that know what they're doing.. Are there bands in these trannys that could be or need to be adjusted..??
Well I just got back from 2 shops, both different diagnosis.. First one said the chatter is caused by slipping clutches, & needs work done.. The second one said the trans oil doesn't smell at all, but the oil should be changed.. But the chatter is caused by 2 bad U-joints (rear).. I did notice a loud clank when shifting from Park or Drive to Reverse.. Funny I did take it to the Dodge dealer in Canada about the clunk, & they said that a certain amount of slop is quite normal.. Made an appointment for tomorrow morning to change the U-joints, & will let you know if that helps the problem, or eliminates it.. The second shop said that there may be some slippage in the tranny, but have to eliminate the U-joints first, & then see.
Could be the bands need adjusting. One of the bands can be adjusted by yourself. The adjustment screw is on the outside of the tranny. I can't rember what the adjusment is supposed to be but it is in DTR just need to do a search for it.
Adjusting bands...look here: http://www.dodgeram.org/tech/transmi...T_band_adj.htm
Steal (maybe borrow) a Texas license plate and put it on your truck so you dont get raked over the coals at a tranny shop.
