hydraulic pump just went out, 97 12v, any installation tips?
Old Jan 29, 2008 | 07:01 PM
heykw's Avatar
If the pump keeps running out of fluid it won’t be good for long
Old Jan 29, 2008 | 07:11 PM
2500's Avatar
purchased a seal kit pitman arm from dealer today. but they didn't have other seal.
got Orielly to order a seal kit with both seals and gaskets. next up is resealing steering box.
reman steering box is $171 worst case. I may put transmission dye in first.
a dodge tech stated ATF-4 was ok to use in my power steering. much rather be using synthetic. sooo is ATF-4 ok to use in my 97 CTD?
Old Jan 29, 2008 | 07:41 PM
vzdude's Avatar
DTR's 'Go to Guy'
ATF +4 is synthetic. Or a blend at least. You can also buy Valvoline synthetic at most parts stores that is ATF+4 compatible. Why take the whole gearbox apart? You can replace the pitman shaft seal pretty easy, without taking it off the truck!
Old Jan 29, 2008 | 07:42 PM
Dave Miller's Avatar
If you end up replacing the steering gear why not ugrade to a PSC 3 turn steering gear. I can steer with one finger.
http://www.pscmotorsports.com/produc...products_id=91
Old Jan 30, 2008 | 12:22 AM
2500's Avatar
thanks... that's what I'm planning on doing first. which is replacing pitman arm seal without dropping gearbox.
VikingDiesel
Aug 12, 2007 10:10 PM
4x4dually
16
Sep 13, 2006 05:05 PM
drew03
76
Feb 6, 2006 07:57 AM
pwrtripls1
Dec 17, 2005 05:38 AM
robox
Oct 7, 2005 01:31 AM
