how to use lock-up switch......?
Old Jun 14, 2009 | 04:09 PM
mysterystench's Avatar
I'm thinking of doing this tonight, after much consideration- it just seems worth it to me. I've been reading a few do's and donts concerning the operation of them. Anybody care to explain how to use this? from acceleration, deceleration, stopping, when to turn on and off, etc....
Old Jun 14, 2009 | 06:29 PM
infidel's Avatar
I only use mine when I'm up to highway speed and plan on staying there.
Old Jun 15, 2009 | 02:30 PM
CarlJensen's Avatar
I use mine all the time when towing my 5ver. No exhaust brake so this helps me a bit. I am very careful about lugging it though, this is a big no no!
Old Jun 16, 2009 | 06:15 AM
Yellow Yota's Avatar
Ditto for me. Only other time is on our steep mountain area logging roads. I'll lock in 2nd to cruise easy at a lower speed and get rid of the heat from the unlocked converter.
It's also real nice to use a relay to switch the lock circuit to ground rather than just a switch by itself. That way, you can use a switch with a light in it to help you remember that it's locked.
Old Jun 16, 2009 | 07:50 AM
CarlJensen's Avatar
I am not sure how your's is wired Yello Yota, but I put an LED on mine. Went to the lock up switch then to a 12vdc source for the other side. When the switch picks up a ground to lock TC it also gives a 12vdc path through the LED. No problem for the lock up, as the LED uses such a small amount of power. Does get a little bright at night as no dimmer is on LED.
Old Jun 16, 2009 | 11:31 AM
cumminsdriver635's Avatar
Locked shifts will break your input shaft with much power. I did it for a long time. I never broke anything doing it with the stock converter. A while after i put my goerend in it though, I twisted the stock input in half doing locked shifts.
3rd and 4th gears are the best place to lock it. A lot of the time i turn my O/D off and when i get to 3rd I lock it, pull through 3rd, let off, shift to O/D and accelerate again. I dont worry too much about locked shifts with my billet input now though.
Eric
smokeum99ta
Feb 29, 2008 07:07 PM
SPLnut
Dec 31, 2007 11:27 AM
mr T
21
Jun 1, 2005 08:48 AM
Nuttymopar
Sep 2, 2004 07:39 AM
damon_achey
Jun 7, 2004 03:33 PM
