How to replace Serpintine belt?
Old Mar 19, 2003 | 10:24 PM
95ramtough's Avatar
When I start my truck when it is cold it squeeks till it warms up. It seems like it has to be the serpintine belt, and it is cracked pretty bad and needs replaced. How much is the belt, and do i need anyspecial tools to untighten/tighten it?<br><br>thanks<br><br>mike
Old Mar 19, 2003 | 11:02 PM
Ruralmedic's Avatar
Re:How to replace Serpintine belt?
The symptom you describe almost sounds like the notorious power steering fluid on the Dodges. The fix for that is changing to a synthetic P/S fluid. <br><br>Otherwise, it would also be a good idea to change the serpentine. For my 24v cost was $20 something at the local auto parts store. A breaker bar w/pipe extension for increased leverage to move the belt tensioner is what I used. Good luck.
Old Mar 19, 2003 | 11:12 PM
Stamey's Avatar
It has an automatic tensioner on it. I just changed mine tonight because it was making all kinds of noise. By the way, belt dressing is the worst [censored] you can put on a belt. It is messy, and a rip off because if it works, it's only temporary.<br>You'll need a 3/8 breaker bar or ratchet, and probably a pipe to extend it for more leverage. I put a 1/2 to 3/8 adapter on my 1/2 ratchet with the long handle. I used the ratchet because I could adjust it for the swing. It will go almost right down to the fan shaft when you get the belt off any let the tensioner down. Pull it off the alternator first, and put it on the alternator last.<br>It will be a pain when you do it the first time, trust me. It's easier now that I've done it 3 times.<br><br>Chris
Old Mar 19, 2003 | 11:22 PM
95ramtough's Avatar
What is involved in switching to synthetic ps fluid? Thanks<br><br>mike
Old Mar 20, 2003 | 12:14 AM
TBGH's Avatar
Use a suction gun, some use a turkey baster to remove the fluid. Refuill, go for a short drive and change fluid once more.<br>John<br>
Old Mar 20, 2003 | 01:26 AM
BigK's Avatar
Come on over to the wet side, and your friendly WADTR #10 Chapter members will be glad to lend a hand!
Old Mar 20, 2003 | 10:36 PM
NAIL BENDER's Avatar
[move][glow=green, 4, 600]WASHINGTON STATE DTR #10[/glow][/move]<br><br><br>Always here to help. Yakima is just a short drive here. ;D
Old Mar 20, 2003 | 10:40 PM
95ramtough's Avatar
someone moved my post to the 24 Valve! I have a 12 vavle! <br><br>I am trying to get some parts together and make a trip to graham... Catback 4&quot; exhaust, KDP killed, advanced timing, and the surpentine belt are my plans... Sounds like I just gotto get a bunch of beer together! haha
moparmatt
May 7, 2007 09:43 AM
C-SIK
Mar 2, 2007 05:25 AM
mitch@jc'sCTD
Feb 23, 2006 07:52 PM
briankk
Oct 19, 2005 03:00 AM
