how much oil burn
how much oil burn
truck has 145k and it seems to go through 2+- qts btween changes, i usually try to change oil at 3 to 4k miles, is this usual or ?. what are you guys seeing.
Check for leaks and blowby under frame. If the undercarriage is well lubricated you may have a issue. A quart in 1000 miles is not unliveable from a overhaul standpoint. Real leaks should be resolved. Sometimes just changing brands of oil will effect a change in consumption. Mine goes through a couple qts in 5000 miles and then settles down and uses perhaps another 2 qts in 15000 miles. Use Rotella syn and change at 20000
SilverRam01
52
Apr 11, 2023 11:36 AM
tesla440
20
Aug 18, 2009 08:51 PM
Sam Turner2
15
Nov 2, 2008 06:53 PM
