How do I remove the timing housing?
Old Dec 28, 2004 | 08:29 PM
stangman67's Avatar
I got the cover off and the injection pump gear off. The four nuts are off the studs and the power steering pump gear is disconnected. I cant get the cam gear off! Is there a way to get it off or does the cam need to come out. The gasket was leaking at the bottom, no broken case from the pin, while idling. So it has to come off to fix the problem. Please help me out!
Thanks. Mike
Old Dec 28, 2004 | 08:38 PM
The cam needs to come out. There's a retainer plate behind the cam, you can reach the bolts through the cam gear by turning the engine over. The tappets are mushroom shaped, so you need to pull all the valve gear, then jam notched dowels down into the tappets to pull the tappets off the cam. Rubber bands are used to hold each pair of dowels in position. There's a site with pretty good pictures of the job, I'll try to find it. Good luck, and don't drop any tappets or you'll get to pull the oil pan.
Old Dec 28, 2004 | 08:43 PM
Here's what you get to do. http://www.flex.net/~triplem/new/dowelpin.htm
I hope you have a warm place to work.
Old Dec 29, 2004 | 10:01 AM
infidel's Avatar
Most dealers repair a leaking case by loosening the bolts, prying the case away from the block, blasting with brake cleaner and then squeezing in silicone RTV. This saves several hours labor and seems to work.
Old Dec 29, 2004 | 11:50 AM
tdiot's Avatar
I too have a leak at the bottom of the timing case. Its small though, not even enough to leave a drip on the ground usually! Question: Are all of the case bolts accessible except for the one behind the cam gear? Has anyone had any sucess with a thin/bent wrench backing that bolt off to loosen the case and then tightening it back up? I plan on doing this sometime soon and trying to get some of that grey silicone up there to see if it cures the leak. Any tips techniques or experiences would help! Thanks.
Old Dec 29, 2004 | 12:54 PM
twoweeks1's Avatar
before I tabbed my killer dowel pin I had a leak and just tighted the bolts and it took car of it You have tabbed your dowel pin right? Mine was so far out i started to pull on it and it fell out!! i was very lucky on when i found out about it and did the fix.
RoadDiesel
Aug 7, 2012 06:06 PM
Opacity
18
May 15, 2008 11:54 AM
Tiara3100
Dec 21, 2007 01:42 PM
Dodgezilla
Jul 17, 2004 05:24 AM
