high performance fuel systems?
Old May 31, 2007 | 12:45 PM
CR785's Avatar
What are you all running for fuel sytems? I am building a pulling truck and want a good fuel system. Right now i got 1/2" line all the way from the tank to the pump. I got a wix filter housing before and after a holley blue fuel pump, no regulator. Will that work or do i need to do something else? I also took out the lift pump and made a plate to cover the hole. What do you all think i should do, like i said this is a pulling truck soi am going to push a lot of hp. Thanks.
Old May 31, 2007 | 01:22 PM
kawi600's Avatar
If youre building a high horsepower truck, Id look into a high end FASS, rasp or mitusa mechanical fuel pump (driven from the balancer).
The stock piston pump on the 2nd gens are supposedly good up to 550hp or so.
The stock fuel filter and fittings may be limiting your fuel flow also.
Old May 31, 2007 | 03:41 PM
TxDiesel007's Avatar
Try
an aeromotive 100 pump, to a pressure regulator in place of the OFV with 1/2 inch lines all around...
that oughta work out well...
if not haisely has a killer auxillary fuel system that can work too.. for a decent price...
Rick
Old May 31, 2007 | 04:33 PM
CR785's Avatar
thanks guys, will the rasp work on 12vs i asked a guy that has one and noone can tell me if it will work on the 12ver or just te 24? Thanks. Also where can i get info on the mitusa?
jrussell
Jun 24, 2009 09:24 PM
spooling
Apr 26, 2008 03:06 AM
BigBully
20
Oct 9, 2007 10:03 AM
wildcard3766
Jun 16, 2004 02:57 PM
James Lucas
Jul 25, 2003 11:24 AM
