hi-idle screw on p-7100
Old Apr 7, 2009 | 07:37 AM
DieselDodd's Avatar
A pump shop opened up my idle screw a while back on my motorhome and i would like to set it back . Where is the hi-idle screw on the p-7100 located? Does someone have pictures? I was told this adjustment can ruin my allison trans in short order and i want to return it to stock position.Thanks.
Old Apr 7, 2009 | 10:47 AM
infidel's Avatar
Picture is small but you should find it
Old Apr 7, 2009 | 12:24 PM
DieselDodd's Avatar
I can,t seem to make out where the high idle adjustment is from the picture and i looked at my pump and just can,t figure it out. Its easy to see on the ve. Any body have a big picture of the p-7100?
Old Apr 7, 2009 | 02:46 PM
j-fox's Avatar
The high idle stop screw is the max wide open , no load, throttle stop. I don't see how this can hurt a trans, but it is your move. Low idle maybe.
Hold the throttle wide open and find the stop screw.
Old Apr 7, 2009 | 04:58 PM
DieselDodd's Avatar
On the motorhome application the frame is in the way and i can,t really see the hi idle stop screw.
Old Apr 7, 2009 | 07:47 PM
infidel's Avatar
I have a ton of them but unfortunately the throttle linkage is removed on all of them.
That's because it has to be removed to take the pump out and get a good picture.
Old Apr 8, 2009 | 04:43 PM
DieselDodd's Avatar
Anybody got big pictures of the low and high idle adjusting screws? I can,t see anything in the motorhome application on the p-7100 becase the frame is in the way. Does the screws have locknuts on them? Thank-you.
Old Apr 8, 2009 | 07:04 PM
DieselDodd's Avatar
I got under the motorhome and i think i found it. Does it have a 10 milimeter lock-nut and a round head with a small hole in it? Do you have to stick something in the small hole and hold it while you undo the lock-nut?
Old Apr 9, 2009 | 10:07 AM
infidel's Avatar
You're asking a question that very few people could answer.
There is really no benefit to turning up the high idle so it's rarely turned up or down. I've dealt with a lot of pumps and have never messed with one.
It's higher rpm without power since the governor will cut back fueling unless you have a GSK.
Even with a GSK you don't have to mess with the high idle.
jmd4993
Jun 22, 2013 07:36 AM
FlaCracker
Oct 23, 2009 02:42 PM
loudcummmin
Oct 3, 2005 02:44 PM
