Here's what I've done so far
Well I bought the truck (the one in my signature) almost 2 months ago. The tranny (auto) would'nt unlock so I had a new t.c. and valve body installed, fixed for now. The rear end was snapping so I changed the dope and friction mod, fixed for now. I changed all the fluids and filters. I pulled the w.g. and it was no good, so I pinched the line, fixed for now. I ordered guages and a piller, and I'm hoping they will be here by tomorrow.
So now for the ????
I was over looking the afc because I want to pull it and check the gov spring. When I was checking everything out I noticed just below the afc and fuel s.off solenoid it was damp. So would that be a fuel leak? what would be causing this leak? I also noticed the rubber fuel line comming off of the metal fuel line above the bell housing looked a bit cracked and dry rotted. Is that a supply line or the overflow line?
The truck gained alot more power when I pinched the w.g. line, but it seems like it wants to give a little more. I am going to order a new overflow valve tomorrow and change it asap.
The truck has the stock exhaust on it with a cat. I plan on choping the cat out until I can order some exhaust. I would like to slide the stock plate forward and washer the gov spring. I have'nt killed the kdp yet and that is a top priority. Does anyone have any pic's on sliding the plate and washering the gov spring?
The truck has 168k on it now and I was able to contact the p.o. and he did nothing to it except routine main. and a tranny or two. Where should I start, I don't want too much more power just what I can get outta stock components (with the exception of a Goerend tranny) Thanks for all the help.
So now for the ????
You are on the right track. Go ahead and replace all fuel lines and be done with it. Im sure there is a thread on the gov. springs the plate is easy to slide you will have it off if you go through the top for the springs.
That's what I thought. When I was checking out the afc the break off screw was still in so this thing has never been touched. What's the best way to get that break off screw out. I thought about tapping a sockett on it slightly smaller than the head of the break off screw, will that work? Or just get the dremel out and cut it?
92smokin blacky
Feb 23, 2011 07:18 PM
COLEMAN1001
38
Jul 5, 2009 08:54 PM
dieselnewbie
Apr 6, 2004 12:22 AM
