HELP! ASAP... Control arms
Old Mar 17, 2009 | 04:45 PM
jdjanetka's Avatar
I had the same problem and used up quite a few sawzall blades gettings those buggers out.I used energy suspension poly bushings and burned out the old rubber ones with a torch(old steel sleeves stay in the arms). I used new dodge bolts up front and sourced class 10.9 m12 bolts from mcmaster carr for the rear. I looked back in my reciepts and these should be the right numbers, bottom eccentric bolts(6504237 $12.84 ea.)/ top bolts 6506033AA $6.12 ea). If you use a sawzall make sure you get a couple packs of new blades . good luck.
Old Mar 17, 2009 | 05:04 PM
Wicked500R's Avatar
Thanks guys! I will be installing aftermarket control arms with new bushings already installed so that part is easy. Getting the old ones out should be fun... I have my torches, Snap-On air hammer, Milwaukee Sawzall, hammers and prybars of all sizes ready to go... I should photograph this process....
PS... alot of people who I see use a sawzall to cut metal go full speed and that WILL kill the blade in a short amount of time... You have to back the speed down when cutting metal and the blades last MUCH longer but they do still wear out.
Old Mar 18, 2009 | 04:46 AM
2nGlenn's Avatar
I with love to see some pictures of the after market Control arms
Glenn
Old Mar 18, 2009 | 04:55 AM
jdjanetka's Avatar
ditto on the blade speed.you'll need some longer blades on some of the bolts and can only use a small portion of the blade. As soon as the blade starts to dull ( metal stops flying) change it out.Cutting with a dull blade at high speed only makes the bolt harder and harder to cut.
Old Mar 18, 2009 | 05:17 AM
Wicked500R's Avatar
Yea, my favorite blades for metal are called "The Torch" and I mostly use the longer ones that are like 10 inches.
ramdiesel23
27
Jun 13, 2011 09:21 PM
Jason Foster
Sep 2, 2008 12:13 PM
Captain
Feb 12, 2008 02:18 PM
Tommy93w350
Jan 4, 2008 10:33 AM
hellotbone
Aug 20, 2003 12:51 PM
