Heater grid , what triggers soleniod ?
Old Dec 8, 2011 | 05:27 PM
SKATERHAULER's Avatar
Been trouble shooting grid heater . Grid Ok , solenoid Ok as well as all connections . When I ground small lug on Sol grid heats up . Simply put where does the Solenoid get signal from ? Is there a fuse somewhere ?
Old Dec 9, 2011 | 08:08 AM
patdaly's Avatar
Signal from PCM, more correctly, PCM drags the coil to ground.
Not sure if the 95 follows the 97, but on 97's, PCM connector C1, pins A9 is relay # 2 control, and C1, pin A7 is relay #1 control.
Check you air intake temperature sensor, that is what I believe tells it it is cold enough to fire.
Old Dec 9, 2011 | 10:31 AM
infidel's Avatar
Everything you need to know about the grids> http://dodgeram.org/tech/dsl/trouble...niford_htr.htm
chadwick
May 18, 2006 06:31 AM
tyssniffen
Mar 26, 2006 07:15 PM
93' Shorty
Oct 28, 2004 01:48 AM
Got Smoke?
May 27, 2003 09:13 AM
