heat exchanger hose???
hi alll,
need the hose that goes in the bottom of the heat exchanger on right side of engine , it is leaking trany fluid !
looks app 6" long with fittings on each end.
wher do i get one and how much does cost ?
thank you !
thank you !
found the replacement hose at summit racing and jeggs !
it is only sold with the steel line that goes to trany output port !
original line is discontinued ,so you also need to buy 2 adapter fittings one for each end < they are different >.
line part no, dorman 624-352
BBWD
Oct 21, 2004 06:29 PM
