heat exchanger hose???
hi alll,
need the hose that goes in the bottom of the heat exchanger on right side of engine , it is leaking trany fluid ! looks app 6" long with fittings on each end. wher do i get one and how much does cost ? thank you ![duhhh] |
found the replacement hose at summit racing and jeggs !
it is only sold with the steel line that goes to trany output port ! original line is discontinued ,so you also need to buy 2 adapter fittings one for each end < they are different >. line part no, dorman 624-352 |
