Hard starts
Old Apr 30, 2006 | 10:36 AM
Flashpoint's Avatar
Hard starts
Seems to me like my 12 valve is hard to start. I think maybe the timing is off ? Or am i just use to my 24V which kicks off as soon as you hit the key. I had a 93 model few years back but if my memory is correct ,I think it fired off as soon as i hit the key also. Any of you DFW guys have the tools to give me a hand with this.
Jeff
Old Apr 30, 2006 | 11:08 AM
ratsun's Avatar
The thing about the P7100 is there are a few adjustments you can play with and if there not set right it makes a difference. Once set right you should be able to reach in and hit the key and it will fire straight off as the vp does (close anyway) Try bumping your idle up a bit that should help.
Old Apr 30, 2006 | 12:49 PM
berner's Avatar
I'd question whether it's your timing unless someone has advanced it. Harder starting is one of the drawbacks of advancing the timing too much.
97catintenn
Jan 7, 2010 11:33 PM
king d
Sep 18, 2005 06:12 AM
blacksheep10
Oct 20, 2004 06:58 PM
Diesel-Dan
Apr 28, 2004 11:33 AM
