Gutted AFC and removed fuel plate!!
Old Nov 28, 2008 | 06:40 PM
Bigsmoke3500's Avatar
my buddy just removed his plate and gutted the lever out of the AFC now his truck after it gets hot idles at 1500 rpm? what do you think could be the problem? it dont seem to smoke as much as i thought it would. it could be because he has stock DV's and injectors right?
thanks,matt
Old Nov 28, 2008 | 06:44 PM
crabbelle's Avatar
no, you dont have any way of tuning the fuel with out that stuff. specially the afc. all your going to get is alot of fuel waaay to soon and high temps
Old Dec 1, 2008 | 07:50 AM
illEatUrDuramax's Avatar
removing all of that is a bad idea. instead, try learning to tune the afc and fuel plate. you may want to buy an aftermarket fuel plate too. try this, i liked this one alot: http://wiki.dieseltruckresource.com/wiki/Pump_Mod%27s
if smoke is what you're wanting, im sure injectors or DVs will help
Old Dec 1, 2008 | 10:02 AM
kawi600's Avatar
Somethign weird going on there. Temperature shouldnt affect the idle speed. Gutting the AFC will make it smoke more off idle but it shouldnt change the idle speed. removing the cam plate will make it smoke more as youre accelerating.
He might want to run this by a diesel tech and see if its not something going on with the rack or the governor springs.
Anyhow, the idle screw is on the back of the pump. Set if for 800RPM hot and see what it does once it starts up cold.
Old Dec 1, 2008 | 10:50 AM
infidel's Avatar
As said removing the plate and lever shouldn't have changed your idle.
Only time I've seen the idle change from getting under the AFC cover was when a guy unknowingly lost a screw in it and ran it.
Idle was all over the place, pump had to be rebuilt.
Brian08Q35004x4
Nov 14, 2010 09:48 PM
94ram
Sep 4, 2009 05:16 PM
Maddog411
21
Feb 29, 2008 07:28 PM
Diesel Dave2
Sep 3, 2007 09:05 AM
smknram
Mar 17, 2007 10:12 PM
