governor arm
Old Jan 12, 2007 | 03:56 PM
96RAM3500's Avatar
governor arm
ok b4 u all yell at me and tell me to use a search........ im just a little confused on adj the governor arm i have a #6 plate and i realize that they say to adjust the lever so the lever hits at the tip of the bottom nose on the plate......... but the 6 plate is sort of confusing can someone post a pic of where exactly the arm shoudl touch on a #6 plate???? thanks
Old Jan 12, 2007 | 04:21 PM
kawi600's Avatar
Id adjust it to sit on top of that large 'nose' on the plate. I have the same one. Believe me, if you do it too low, youll know! The arm will stick there and youll have no power on the low end at all.
Old Jan 12, 2007 | 08:10 PM
96RAM3500's Avatar
yea thats how it is now.... n othin down low at all!!! very comparible to stock.....so make the bottom edge of the governor arm level or above the outermost hump on the plate??? i wish i could draw a pic right now lol
Old Jan 12, 2007 | 08:16 PM
kawi600's Avatar
Its the largest peak on the plate, cant miss it. On top of that edge and youll be all set.
Old Jan 12, 2007 | 09:00 PM
96RAM3500's Avatar
kinda lol im sorry for being a pain in the a@#
Old Jan 12, 2007 | 09:39 PM
12valve's Avatar
between the 2 points. it doesnt really matter, as long as it hits the plate. if you screw it so it'll go above the edge where you wrote "here???" the adj screw may fall out, it aint too long on 96 truck
if it rides under the plate (with the fuel shut off solenoid poulled up, then you may loose power!
at least 1/8" from the very bottom i'd say
Old Jan 13, 2007 | 11:45 AM
96RAM3500's Avatar
ok thank u very much
kawi600
Jan 16, 2006 02:13 PM
kawi600
Jan 8, 2006 05:12 PM
Iron City
Dec 1, 2005 09:03 AM
inline6359
Nov 30, 2005 09:51 PM
cumminsdriver635
Nov 20, 2004 12:59 PM
