Fuel Systems/ Fuel Pump ?????
Old Oct 4, 2007 | 01:57 PM
BigBully's Avatar
I ended up running 2 Modified pumps and still lose pressure at WOT. Do I need to do something to the Banjo bolts or something? It just seems the pumps cant pump it in there fast enough.
Old Oct 5, 2007 | 12:54 PM
infidel's Avatar
You must have a clog, kink or other problem inbetween the tank and engine that's restricting flow.
I know several folks pushing 600 hp with the stock delivery system no problem.
Old Oct 7, 2007 | 09:25 PM
BigBully's Avatar
There might be some kind of clog or something but I sure dont know where it would be.
I am now thinking of putting in a more performance type of fuel filter, Can someone tell me what the little line is for that runs from the injectors back to the filter? Also When you put that remote filter bracket on that Cummins sells where does that little line go?
Old Oct 8, 2007 | 10:06 AM
infidel's Avatar
The small line is the return from the injectors.
Besides returning fuel it also keeps the fuel in the filter warmer which helps with gelling.
My understanding is the small line must return to the pressure side of the lift pump, returning it to the zero pressure return line messes things up.
Old Oct 8, 2007 | 10:11 PM
BigBully's Avatar
So would I be safe to Tee it (Jector return) into the pressure feed from the electric pump?
Old Oct 9, 2007 | 10:03 AM
infidel's Avatar
Absolutely
spooling
Apr 26, 2008 03:06 AM
Ph4tty
May 8, 2007 08:38 PM
Diesel Dave
15
Mar 18, 2005 10:06 AM
wildcard3766
Jun 16, 2004 02:57 PM
James Lucas
Jul 25, 2003 11:24 AM
