Is this the fuel system?
Old Apr 7, 2010 | 12:12 PM
buffaloslobber's Avatar
Question Is this the fuel system?
When towing a load at 60+ MPH my truck will vibrate for about 5 seconds and then the vibration will stop for about 5 seconds and then it will repeat until I stop (and when I stop when this is happening it usually dies) has anyone had this happen before? The fuel filter doesn't even have 3k miles on it and the air filter has about the same. It is a '95 12 valve.
Old Apr 7, 2010 | 06:36 PM
infidel's Avatar
Best way to find out is to install a fuel pressure gauge even if it's just temporary.
Instructions> http://www.cumminsforum.com/forum/94...-12-valve.html
or you could just replace the overflow valve, $39 from ebay.
Old Apr 11, 2010 | 05:39 PM
TOMCREEK's Avatar
it is probably drawing air most likely in the fuel heater element or through the o ring in the element housing clean out the screen while you have it off.the o ring gets old and will get hard it might look fine but it wont seal. check any rubber hose connections in the fuel lines.most people buy a new transfer pump only to find the before mentioned was the problem.you can find the screen & o ring kit at genos garage for 7or8 dollars.I cant say for sure this is your problem but is a good place to start.
Old Apr 22, 2010 | 12:23 AM
thanks
RiverRat2
Oct 15, 2019 10:59 AM
ado2b1
Jul 6, 2007 09:35 PM
DISTURBED
Mar 11, 2007 09:14 AM
chucktownsend5
Mar 8, 2005 08:21 PM
