Fuel Shutoff solenoid
So I had a issue with mine cleaned it up an greased lightly and it seems to be working good now but still have parts ( boot and relay ) coming from Larry B's.
I would have to keep starter rolling for 8 or 9 sec. and mash the gas to the floor ( on a cold day almost couldn't get it to go ) to get it to run, after it started it ran like new when I shut it off I would cycle the key 3 or 4 times then it would fire.
Before cleaning I would lift plunger up and it work like it was suppose to but noticed I could still push plunger up 3/8" to 1/2" to the top after it was running.After cleaning it's full pull to the top, with the key on only before starting rod is down but after I start it's now full top and no play left. Does it stay down when on key then go up and stay up after starting.
