Fuel shut off
Old May 11, 2007 | 02:47 PM
Ocmechanx's Avatar
Fuel shut off
Wheres the cheapest place you know of to get a fuel shutoff solenoid?
cummins wants like 262
I got a PTO cable thats ALOT cheaper than that.
Thanks Bryan
Old May 11, 2007 | 02:59 PM
John Faughn's Avatar
Try here .
http://www.fostertruck.com/dodge/default.htm
Old May 11, 2007 | 05:18 PM
Box5's Avatar
Direct replacement Fuel shutoff selenoid $185
http://www.citydiesel.net/shutoff-so...cPath=22_26_48
Fuel selenoid that needs a adapter $159
adapter $18
Old May 11, 2007 | 07:28 PM
kd460's Avatar
http://cgi.ebay.com/ebaymotors/94-98...spagenameZWDVW
Old May 11, 2007 | 07:30 PM
infidel's Avatar
DON'T REPLACE THE SOLENOID!!!
Likely nothing is wrong with it unless it is very visibly burned up on the outside.
The solenoid is probably the most needlessly replaced item on a 12 valve, expensive too. The solenoid is a very simple, sturdy device that will easily last the life of the truck. It either works or it doesn't, there is no such thing as one getting weak.
The problem is almost always a corroded blue wire from the driver's side battery or a bad relay on the firewall. The rubber boot that protects the solenoid can fall apart allowing gunk and rust to bind the solenoid, clean it up and replace the boot.
Relay and boot are availible for a good price here http://www.fostertruck.com/dodge/default.htm
Smokkin
Apr 4, 2012 02:43 PM
dkimmel
Jan 3, 2011 10:54 PM
randyswelding
Feb 9, 2009 10:40 PM
Dean Snow
Sep 26, 2007 03:40 PM
doomgaze
Dec 12, 2002 05:18 PM
