fuel pressure ?
Old Feb 23, 2010 | 02:41 PM
daveybones's Avatar
fuel pressure ?
where do i test fuel pressure and what are the specs? My problem is no power. Runs great, no miss. I can only build about 12 lbs of boost even under load. What are boost specs ? Can I test pressure on top of filter housing, 10 mm bolt?
Old Feb 23, 2010 | 03:51 PM
guhfluh's Avatar
Yes you can test pressure from the top of the filter housing. Search and find(maybe in archives or sticky on top) where you can tap a banjo bolt, install a valve for very cheap. Something like 22-25psi at idle I think for a 12v.
Boost should be higher under full load. 18psi or so, give or take some.
Fill out your sig and people will be more willing to help if they know what truck you are asking about specifically.
Old Feb 23, 2010 | 07:20 PM
infidel's Avatar
Here you go> http://www.cumminsforum.com/forum/94...-12-valve.html
Old Feb 26, 2010 | 07:48 AM
daveybones's Avatar
1994 2wd 3500 Dump Fuel pressure? / No power
I have 25psi fuel at idle. As soon as I get it back into the garage I will check 2500 rpm fuel press and fuel pressure under load. If that checks OK what should I look for next ? As far as I know vehicle has never been maintained all that well and I,m sure it has no performance upgrades. I got it from a mason who used it for work and then sat for 10 yrs. We did pull the screen to check for debris but that was suprisingly clean.
Old Feb 26, 2010 | 09:59 AM
infidel's Avatar
Very common for the timing to slip on these engines.
Instructions> http://dodgeram.info/tsb/1994/18-10-94a.htm
but you need special tools, may be cheaper to pay someone else to do it.
Just make sure they use the method in these instructions.
Many mechanics will say they can do the timing but use the guesstimate method.
Make sure all the filters are clean and that the line that goes from the back of the injection pump to the turbo is intact.
dodgeguy71
17
Jan 19, 2012 12:52 AM
bigragu
Jan 24, 2006 11:16 AM
mtl0727
Nov 5, 2005 06:47 PM
darrenG
Jun 28, 2005 07:43 AM
Flatty
Jan 5, 2005 02:50 PM
