Fuel Pressure
Old Feb 9, 2009 | 01:36 PM
El Borrego's Avatar
Fuel Pressure
I have a friend that has a 1997 5.9 Dodge Diesel tow truck. He says that his engine has a "screen pump" and a fuel pump. He has replaced the original fuel pump with an in-line electric pump. He has also installed an in-line filter. His engine when idling will start to die as if starving for fuel but you can bump accelerator and it catches back up. He is wanting to add a fuel pressure gauge but doesn't know where it should be added. Would appreciate any assistance. He doesn't have access to a computer and is missing out on being able to ask these questions from this type forum.
Old Feb 9, 2009 | 05:30 PM
Dartmouth 12V's Avatar
If you do a search, you will probably find pictures but here is a verbal description.
Take the banjo bolt at the inlet to the injection pump(rear outside top of pump) and drill and tap it for the fuel pressure gauge. I would recommend drilling down through the bolt as that will help you make sure to be centered. You can buy an entire kit from several sources, I would recommend dieselmanor which you can find online.
Old Feb 9, 2009 | 07:05 PM
infidel's Avatar
Here you go Checking 12 Valve Fuel Pressure
Old Feb 10, 2009 | 02:03 PM
El Borrego's Avatar
Fuel Pressure
Thanks to you both, Darthmouth 12V and Infidel for the information. I'll call my friend over tonight and give him the print-out.
El Borrego
dodgeguy71
17
Jan 19, 2012 12:52 AM
bigragu
Jan 24, 2006 11:16 AM
mtl0727
Nov 5, 2005 06:47 PM
darrenG
Jun 28, 2005 07:43 AM
Flatty
Jan 5, 2005 02:50 PM
