Fuel press. gauge install ?
Old Feb 5, 2006 | 08:24 AM
Mr. Jimmy's Avatar
Where is the best place to hook up my fuel pressure gauge on my 95 12V and what size is the port? Is it possible to use a needle valve at the port so that I can use this for shutting off if the nylon line begins to leak?
95 12V CC 4WD Auto
Old Feb 5, 2006 | 08:42 AM
Mr. Jimmy's Avatar
Well, I went back and did some searching after posting this question and found a great article with pic by infidel, he sure has bailed me out more than once
Old Feb 5, 2006 | 01:39 PM
Dr. Evil's Avatar
Follow Infidel's other advice - use 1/8" air brake line with 1/4" tubing over top of it for abrasion resistance, rather than the nylon boost stuff.
Old Feb 5, 2006 | 02:51 PM
Mr. Jimmy's Avatar
Where can I find air brake line? Is this similiar to the nylon tubing?
Old Feb 5, 2006 | 02:55 PM
Dr. Evil's Avatar
NAPA should have 1/8" air brake line.
Yeah, it is similar to the nylon stuff but is made from something else.
Old Feb 5, 2006 | 03:03 PM
Mr. Jimmy's Avatar
thanks Dr, I'll check with them. I've got my gauge and needle valve on order from surplus supply.
Old Feb 6, 2006 | 08:10 PM
signature600's Avatar
I don't suppose you could post a link to that article by Bill could you? I've got a gauge I need to hook up someday, too!
Where did you mount your's?? Anyone have any underhood mounting opinions or locations?
Thanks,
Chris
Old Feb 6, 2006 | 09:26 PM
Dr. Evil's Avatar
Thanks,
Chris
No problem...here you go Chris:
https://www.dieseltruckresource.com/...595#post842595
As well, check out Bil's post here as he has a pic of the needle valve and banjo install on a 12V:
https://www.dieseltruckresource.com/...ad.php?t=88133
Prostar 190
15
Feb 12, 2009 07:30 PM
j
Oct 25, 2008 04:32 PM
j
May 16, 2007 08:11 PM
QWKRTNU
Oct 16, 2006 03:09 PM
Cat Cracker
Oct 13, 2002 12:54 PM
