Fuel Mileage, Comparing Apples to Apples
My past trucks:
'97 ext. cab 4x4 5 spd #11 plate = 21mpg hwy & 18 city
'95 ext cab 2wd 5 spd #10 plate = 22mpg hwy & 18 city
'01 crew cab auto, injectors & box = 18 hwy & 14 city (stock got the same #'s)
'05 crew cad auto, stock = 18 hwy, 16 city
Current truck (last two years):
'97 ext. cab 4x4 auto:
stock = 20 hwy & 15 city
#10 plate, ddp3 injectors & tranny work = 21.5 hwy & 17 city
winter fuels I get 1 to 2 mpg less.
my last tank full I got 14.9 mpg (city driving w/winter fuel w/lots of idle time)
My past trucks:
samahi72,
14 sound about right for a stock truck in city driving. Do you also get 14 on the highway?
Things that could be checked:
1)fuel filter(s). There is a screen in the fuel heater than needs to be cleaned every so often.
2) is torque converter locking when its supposed to? could also adjust bands in transmission.
3)Is timing correct? Advancing it 1° could result in a little mileage gain.
4)tire pressure up? I run 55lb in rear and 50lb in front.
5)air filter clean?
6)Lots of idle time will kill good mpg's
Hope this helps,
Tom
5)air filter clean?
Hope this helps,
Tom
'97 extended cab, long box, 4wd, 12v, 5 speed. Montana to Delaware and back averaged 20 mpg running 75+ on interstates, as low as 55 on secondary roads. Around town 12 - 13 mpg, but that's measured just this winter with winter fuel, I generally gain 1 - 2 mpg with summer fuel. While fighting fuel system problems last summer mileage dropped to 12 - 13 on the highway, came back up when the wastegate actuator, fuel pump and catalytic converter were replaced, two leaks in the intake system were eliminated and the fuel plate was repositioned (it had come loose and was cocked sideways).
My '96 extended cab LB 4x4 averages between 18 and 19 mpg in combined driving. I've never gotten less than 15 regardless of how I drive. The truck has 200k, and a bed cap if that makes a difference.
This truck can also use wvo. The numbers I gave are for diesel only, but from the mileage others are quoting it doesn't appear that running wvo has hurt the effeciency of the engine.
Common
May 4, 2007 02:22 PM
miketriton
Apr 22, 2005 01:14 PM
OT-OF-Here
Aug 7, 2004 07:56 PM
