front drive shaft
Old Dec 13, 2003 | 10:22 AM
cwbronc's Avatar
front drive shaft
I was hearing a noise sometimes when I was in 4wd, but couldn't find it. I was checking fluids when I saw what looks like part of the joint is cracked. Is this common? Also should I be able to spin my front drive shaft with my hand if it's in 2wd? I know it is vacuum actuated, and the T-case is manual, but just not sure what disconects with the vacuum and what disconects with the shifter. Dumb question, but still trying to figure it all out. Thanks.
Old Dec 13, 2003 | 01:18 PM
RCW's Avatar
RCW
Re:front drive shaft
The front drive shaft will turn if the truck is in 2 wheel drive and all the wheels are on the ground. It will be a bit difficult to turn, as it also turns the differential and the unlocked axle side backwards.
The universal joints do not crack all that often on the front driveshaft. However the steering knuckle universal joints do crack with some frequency on the front axle shafts.
By the way, you cannot turn the axle shafts with the truck wheels on the ground.
If you need universal joints, do not bother going to Dodge, go to one of the DANA axle part aftermarket suppliers, and get the new super duty joints (they cost about half what Dodge charges for the cheap OEM joint).
Old Dec 13, 2003 | 04:30 PM
cwbronc's Avatar
Thanks for the reply. That clears it all up. I was wondering what the resistance was when I turned the drive shaft. Would anyone happen to know what type of a price range that I should expect? I guess if it broke I've gotta make it stronger! Thanks again-
Old Dec 13, 2003 | 09:42 PM
radixr's Avatar
I got Spicer greasable joints when I replaced mine.
Old Dec 14, 2003 | 03:41 AM
cwbronc's Avatar
Thanks I'll check them out.
Old Dec 14, 2003 | 12:12 PM
Helicopter Dan's Avatar
non greaseable ujoints are actually stronger if you need the extra strength just a fyi
Old Dec 14, 2003 | 10:32 PM
cwbronc's Avatar
Thanks Helicopter Dan. I'll keep that in mind.
Old Dec 14, 2003 | 11:23 PM
sure no problem
Old Dec 21, 2003 | 02:39 PM
cwbronc's Avatar
I'm just making sure before I go and buy the wrong part, but is the part broken on the front drive shaft the cv joint? here is a link to the pics--https://www.dieseltruckresource.com/yabbse/gallery/displayimage.php?album=445&pid=3624
-the other pics are in the CWBRONC pics folder. If anyone can make out what I'm trying to show and can tell me that'd be great. Thanks again.
Old Dec 21, 2003 | 02:41 PM
cwbronc's Avatar
I don't think that link works, but I hope this one will...
https://www.dieseltruckresource.com/...ex.php?page=56
If not it is page 56 of the pic folders under CWBRONC...
Old Dec 21, 2003 | 02:48 PM
kandgo's Avatar
That is a cv joint,is this what is broken?? If it is then go to Dana as stated above, Goodluck Rick
MCMLV
Oct 19, 2004 08:36 AM
TON4FUN
Aug 2, 2004 07:58 PM
shaft
Jun 30, 2003 02:37 PM
bkay
Dec 12, 2002 05:22 PM
