Fleetguard oil filters-which one?
Old May 22, 2003 | 06:39 PM
2nGlenn's Avatar
Can I use a Fleetguard LF3894 (Stratopore) on my 96 12V? I am a little confused because someplaces list the LF3552 (Microglass) for the 12V and LF3894 for the 24V as the upgrade filters. Thanks
Glenn
Old May 22, 2003 | 09:17 PM
MDKram's Avatar
Re:Fleetguard oil filters-which one?
LF3894 is the best &quot;direct fit&quot; filter money can buy for your engine.<br>Marc
Old May 23, 2003 | 08:35 PM
1dslram's Avatar
The LF3894 is not listed for the 12V engines, only the 24V. The Microglass filter #LF3552 is listed for the 12V engines.
Old May 26, 2003 | 12:27 AM
2nGlenn's Avatar
This is what I am talking about , some say it will work on the 12V and others say 24V only. I know that it is the same physical size and treads but maybe there is some other reason like, the bypass valve is different or the can is stronger (for higher pressures) or an anti-drainback valve. I like the idea of the Stratopore design and would like to run it on my 12V, but would still like to know why it is not listed for my application?<br><br>Glenn
Old May 26, 2003 | 12:49 AM
MDKram's Avatar
Use the LF 3894 for the best filtration. You can use a 24 valve filter on a 12 valve but not the other way around. The 24 valve filters are designed for higher oil pressure and thus the compatibilty I listed above.
Old Jun 8, 2003 | 07:54 AM
Tgrfan2's Avatar
Try fleetguardfilters.com for information.
bcfitzsimons
Jun 26, 2008 12:17 PM
gnuesse
Jan 1, 2006 11:56 PM
2002cumTRBODSL
Dec 16, 2005 08:46 PM
GSP
Dec 15, 2005 05:41 PM
FMF MX
Feb 6, 2003 05:25 PM
