Finding TDC using the valves and barring tool - Looking for link
Old Feb 25, 2009 | 10:58 AM
bob95065's Avatar
I remember reading a post once that gave a procedure for finding TDC by running a valve adjuster down two full turns and rotating the engine very slowly and carefully clockwise until the piston contacted the valve. At this point you scribe a line on the harmonic balancer. Then you rotate the crankshaft CCW until the piston contacts the valve. Again you scribe a line. Then you scribe a line exactly centered between the first tow lines and you have TDC.
Does anyone know a link for this procedure? Anyone have experience? I want to check/set my timing and want to set TDC a little more accurately than using the cam plug.
Thanks,
Bob
Old Feb 25, 2009 | 05:35 PM
infidel's Avatar
Don't know about the two turns, I always heard to just to tighten them down then rock it back and forth.
You are smart to use a method other than the pin, I've found them to always be wrong.
Personally my method is a dial indicator down the #1 injector bore to find the top of the stroke.
Old Feb 25, 2009 | 08:52 PM
Tate's Avatar
I use a dial when I do the drop valve method, so I can run the valve back up to bar the engine past TDC, then set it back down the same depth. Other than that, you pretty much have it down pat.
snic
15
Jun 14, 2017 11:29 AM
tool
Jan 10, 2007 04:19 PM
Pureliving
Jul 21, 2004 05:42 PM
1320
Apr 27, 2004 11:53 AM
