Finding TDC without a barring tool....
Old Jan 7, 2007 | 12:52 PM
tool's Avatar
So I pull my valve cover.....
Wow am I ever surprised how clean the top of that motor is! There is no carbon/ coked oil and general "splooge" that is often built up in the valve covers of other tractor/truck engines I've pulled apart. Very impressed. I guess regular Rotella changes have been well worth it.
Since I don't have a barring tool I figured I could just roll it over with the alternator nut...... No Joy! Just slips on the belt with little resistance.
I guess my serpentine belt must be stretched/ worn out??
Anyone else have any great ideas for rolling that pig over to find TDC??? Besides putting it back together driving 1.5 hours to go to town and get a new belt?
I'm sure one of y'all has an ingenious idea.
Thanks.
Old Jan 7, 2007 | 01:45 PM
John DiMartino's Avatar
Turn it over backwards with the alt belt,it should work fine.Ive done that quite a few times.Ive never had the belt slip,exc that time there was oil on it from the head gasket If its an auto,you can remove the 3 5/16" headed bolts on the TC inspection cover,and use a large screwdriver between the flywheel teeth to turn it over.Pry against the trans case,and it will turn right over.
Old Jan 8, 2007 | 02:06 PM
tool's Avatar
No it won't turn backward..... just slips easily
Truck is the one in my signature, a 5 speed so that trick won't work either
Old Jan 8, 2007 | 02:36 PM
John Faughn's Avatar
Get a socket on the crank , turn slow as to let the compression leak by piston and not unscrew bolt .
Are you looking to find TDC still or just turn over eng. ?
Companion method , almost any eng. , divide firing order in 2 colums , the top 2 numbers are companion cylinders , for the 5.9 they are #1 -#6 , take valve cover off # 6 , turn eng. over till the rockers are just begining to move in opessent directions at the same time , I like to mount a pointer at this time for future use , also mark balancer .
Old Jan 8, 2007 | 08:51 PM
klc99's Avatar
You can put the truck in 4th or 5th gear, jack up one rear tire, and turn it.
Good luck
Old Jan 8, 2007 | 10:20 PM
Tate's Avatar
There are TDC marks on the pump gear and timing cover.
Old Jan 9, 2007 | 10:19 AM
tool's Avatar
Yeah I had the breather cove off, ard to see the mark on the gear though as the rad and air to air are in the way......
Wonder how much the barring tool costs??
Cant say I've ever tried to roll it over by hand by jacking up a tire, the amount of compression these things have seems doubtful..... But I never tried or thought of that one, sounds like a good idea.
Old Jan 9, 2007 | 10:24 AM
The barring tool cost about $35 depending on where you get it , I've read some post lately that talked about Cummins have a maintainace set for $49 , then if you join the power service club at Cummins you get a discount , it cost about $19 , the savings on my 1st buy was more that the cost of joining , and I only spent about $50 .
Old Jan 9, 2007 | 10:33 PM
Tate's Avatar
Inspection mirror makes it a piece of cake.
Old Jan 10, 2007 | 02:38 PM
TIMMY22's Avatar
http://cgi.ebay.com/ebaymotors/CUMMI...spagenameZWDVW
Old Jan 10, 2007 | 04:19 PM
johnh's Avatar
barring tool
pm me, i have one i have never used
moparfan
Jan 28, 2021 11:06 AM
snic
15
Jun 14, 2017 11:29 AM
bob95065
Feb 25, 2009 08:52 PM
keithplacervill
Dec 24, 2005 08:53 PM
Pureliving
Jul 21, 2004 05:42 PM
