exhaust brake
exhaust brake
Who makes a exhaust brake for CTD manual transmissions? I checked banks website and the only make them for Auto's... Is a exhaust brake a auto tranny gismo only??
Pacbrake, BD, and Jacobs all make exhaust brakes for the manual transmission trucks. I use Pacbrake, as their warranty, if needed has proven to be the best I have ever experienced.
Once you drive with the brake, you will wonder how you ever lived without it.
Originally Posted by CTD NUT
Are those the brakes that use a blow off valve?
B-D brake on my 3500 manual for ten years now, never a problem.
I have a Banks Brake on my truck, and it makes a lot of difference towing.
I have had major problems with it however.
On the way home from Banks in Calif, the tiny circlip holding the vacuum piston rod to the lever crank pin fell off, the factory had installed the wrong size clip. So, I limped home with high EGT's the last 100 miles.
I installed the right size circlip, and it worked for awhile. but then while on vacation last summer...
The crank pin in the actuator lever broke off and I had to wire the thing open so I could limp very slowly the remaining 200 miles into my parents' house (pulling my 30' travel trailer).
My dad turned a redesigned pin on the lathe and we got the thing running again.
The force exerted on the lever is substantial, maybe 100 lbs, so be sure whatever brake unit you purchase is constructed so that repeated actuations won't break off the crank.
Originally Posted by infidel
As far as I know none use a blow-off, they all work via a butterfly in the exhaust stream that blocks off flow, the engine is basically working against a restriction. It's almost like the engine becomes a compressor.
Ok, I get it now, you are calling the hole in the butterfly a blowoff?
If you plug the hole in a Pac you also have to upgrade to 60 lb valve springs.
Pac is the only brake I know of where you don't have to absolutely upgrade the springs up until 60 lb springs became stock.
The Pacbrake is on my 24v so I don't have to bother with any valve spring changes.....are you saying I could just go ahead and block the the small hole in the butterfly without any ill effects? How does exccessive pressure bleed off without the hole? Or does it matter? I thought that is why the blow off/bypass valves were used on some of these brakes with no hole in the butterfly - to stop the build up of exccessive back pressure.
coalburner400
Aug 1, 2006 06:37 PM
2500TurboDodge
Jun 28, 2005 09:52 PM
