Engine will not start/turn over
Old Sep 17, 2006 | 06:41 PM
hoofnaround's Avatar
Question Engine will not start/turn over
Recently, our Dodge 2500 began having starting problems. When you turn the ignition, you hear the starting solenoid click however the engine will not turn over. Both batteries are fully charged, the alternator is working perfectly, all battery cables are firmly attached... after a couple of attempts, the engine will eventually crank (anywhere from a 1 minute to a 1 hour effort). Any ideas?
thanks!
Hoof
Old Sep 17, 2006 | 06:46 PM
infidel's Avatar
Replace the starter contacts.
Get new ones here http://www.fostertruck.com/dodge/default.htm
In the meantime you can usually get the starter to kick in by tapping on it with a hammer, rock or whatever you find nearby.
Old Sep 18, 2006 | 05:54 PM
BCB's Avatar
BCB
he is right had the same thing happen on my truck. put the new contacts in and worked like new.
Old Sep 18, 2006 | 06:13 PM
mr T's Avatar
contacts...easy job...u can get them matched up at any starter place..same with the plunger...they cost me 10$ plunger and 5$ contacts up here...or u can get them from fosters....hardest part is the removal of the top bolt of the starter...they're 10mm ..use the star shaped part of ur wrenches
oliverbutthead
May 8, 2015 08:30 PM
FirstGen1991
Dec 22, 2012 04:24 PM
stealman1
Nov 9, 2007 11:07 AM
ktpul
Feb 13, 2006 08:01 PM
bigfoot
Aug 14, 2004 02:22 PM
