engine strorage
Old Oct 3, 2004 | 05:50 PM
CJ's Avatar
CJ
engine strorage
A buddy of mine just got a 90 one ton w/ a cummins. The truck is junk but only has 150k on it. He eventualy wants to put this motor in a crew cab chevy but for now his wife says the truck must go. He will be pulling the engine and tranny and storing them in his shop. His question is: Is there anything special that needs to be done to the engine to store it for a long term? Will there be a problem w/ seals in the injector pump drying up? I sugested changing the oil and filter and running it for a while to get fresh oil through out. Anything else need done?
CJ
Old Oct 3, 2004 | 06:23 PM
Just make sure all the open ports, fittings, etc. are capped/plugged as necessary. Don't forget about the breather tube. Try to store it somewhere dry and as temperature stable as possible.
Old Oct 3, 2004 | 06:47 PM
CJ's Avatar
CJ
wannadiesel. thanks I will pass this along
CJ
Old Oct 4, 2004 | 11:32 PM
96_12V's Avatar
Probably not a bad idea to spray a little engine paint at it as well once it's all stripped out of the truck and then perhaps coat the freshly painted engine with a grease-like substance such that moisture dosen't cause excess rust. Store it on a stand, covered, in a reasonably temperature stable place if possible. Be sure that mice and other critters cannot get inside (along with moisture, etc.) and wreak havoc in those cylinder bores!
Old Oct 4, 2004 | 11:42 PM
CJ's Avatar
CJ
96_12v, it will be stored inside a shop and as suggested above all holes will be plugged I just hope I can talk him into starting the project before rust is an issue Thanks for more ideas
CJ
choppers555
Aug 10, 2008 02:00 PM
alltimelow1
Apr 6, 2005 07:28 PM
Stevenc
Dec 28, 2004 08:29 PM
apache
Feb 22, 2004 05:27 PM
